Joseph Badu mensah
- Nov 26, 2022
- 1
On our pressure regulating skid (4"), one of the two slum shut valves on the line trips frequently with a low-pressure indication on the SCADA. Due to the frequent trips, we have engaged both lines to run simultaneously to avoid tripping the turbines in the event of the SSV shut. Both SSV has different pressure set points 33.1barg and 32.5barg respectively with regulator set pressure of 28.9barg.
I have two questions:
1. What must be the cause the frequent shut of the SSV.
2. Is it practically advisable to run both lines simultaneously
3. Is it practically prudent to give the SSV's different set values.
