Wisconsin Enrolled Commercial Building Code and BOCA both, similarly state "...foundation walls, piers and other permanent supports of buildings and structures ...shall extend below the frost line of the locality.
As a general rule in my area of Wisconsin, we assume frost levels to be 40-48" below grade. This, however, has only been, to my knowledge, a well-accepted common assumption.
I need to determine the frost depth in Philips, Wisconsin, which is further north from my area.
Does anyone have or know of a handy map, chart or useful reference showing frost depths per locality?
Thank you!
Thank you!
