lj1970
Marine/Ocean
- Nov 26, 2023
- 18
Hello guys,
I am excited to share my latest journal to you all. This time infused with a touch of Lord Voldemort's unique style.
The tool automates the process of analyzing and annotating the dimensions and material thicknesses of parts in a Siemens NX assembly. It is designed specifically to aid engineers and CAD designers like myself in efficiently processing and documenting crucial measurements directly within the NX framework.
Features:
- Component Analysis: The script iterates through all components in the main assembly, including subassemblies, calculating the dimensions of each component. It intelligently handles duplicated components by skipping them.
Based on this sub, created by NXJournaling on 2012.
- Bounding Box Calculation: For the designated body, the script creates a non-aligned bounding box to determine its width, depth, and height. The body doesn't have to be aligned with the absolute coordinate system. The process involves generating a non-aligned minimum bounding box, selecting the first vertex on it, iterating through the edges that share a common point with this vertex, and then accurately measuring these three edges .
Solid Body Requirements:
If the body is on Layer 1, it will be processed.
If on any layer other than Layer 1, it will be skipped.
If multiple bodies are on Layer 1, the script will skip the component.
Dimensions are in millimeters.
- Material Thickness Identification: The script determines the material thickness from a pre-set range of valid thicknesses, adjusting the value according to specific criteria. Refer to the code comments for customization to your environment.
- Dimension Sorting: The script sorts the calculated dimensions to identify the length, width, and material thickness of each component. If the material thickness is indeterminable, the script designates the smallest dimension as the thickness.
- User Interaction: The script includes a form interface for user adjustments to dimensions (additional length and width) and to modify grain direction as required.
- Attribute Assignment: Attributes for length, width, and material thickness are added to each associated component / Part. Refer to the code comments for customization to your environment.
Use Case:
Ideal for mechanical engineers and designers using Siemens NX who need a fast, automated method to document and review dimensions and material thicknesses of components in complex assemblies. This tool is particularly valuable in large-scale projects where manual measurement is impractical.
The code has been tested on versions 2212 and 2306 with Teamcenter 13.
Additionally, a professional version is attached, but feel free to modify and add your personal style.
I have several other publications that you might find beneficial, although I was uncertain if this would be the appropriate forum to share them.
Happy Holidays
Enjoy!
Features:
Use Case:
Happy Holidays
Enjoy!
Code:
' created by Tamas Woller at 27.12.2023
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Assemblies
Imports System.Drawing
Imports System.Windows.Forms
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim lw As ListingWindow = theSession.ListingWindow
Dim theUFSession As UFSession = UFSession.GetUFSession()
Dim theUI As UI = UI.GetUI()
Dim workPart As Part = theSession.Parts.Work
Dim Length As Double
Dim Width As Double
Dim winFormLocationX As Integer = 317 ' Default X position for Winforms
Dim winFormLocationY As Integer = 317 ' Default Y position for Winforms
' Use a Dictionary to track processed components
Private ProcessedComponents As New Dictionary(Of String, Boolean)
Sub Main()
Dim markId1 As NXOpen.Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Dimensions Tool")
lw.Open()
' Make all components visible
Dim showhide As Integer = theSession.DisplayManager.ShowByType(DisplayManager.ShowHideType.All, DisplayManager.ShowHideScope.AnyInAssembly)
workPart.ModelingViews.WorkView.FitAfterShowOrHide(NXOpen.View.ShowOrHideType.ShowOnly)
Try
Dim dispPart As Part = theSession.Parts.Display
Dim ca As ComponentAssembly = dispPart.ComponentAssembly
If Not IsNothing(dispPart) Then
lw.WriteLine("---------------------------------------------- ")
lw.WriteLine("Lord Voldemort's Dimensions Tool")
lw.WriteLine(" ")
lw.WriteLine("The ritual of dimensions begins.")
lw.WriteLine("Behold, Width, Height, and Material Thickness.")
lw.WriteLine(" ")
lw.WriteLine("The Main Assembly reveals itself as: " & dispPart.Name)
lw.WriteLine(" ")
ReportComponentChildren(ca.RootComponent)
Else
lw.WriteLine("This part is devoid of any components, much like a soul without magic.")
End If
Catch e As Exception
theSession.ListingWindow.WriteLine("Failure? Impossible! " & e.ToString)
Finally
' Reset to main assembly
lw.WriteLine(" ")
lw.WriteLine("Returning home to the main assembly, like a serpent to its lair.")
ResetToMainAssembly()
End Try
End Sub
Sub ReportComponentChildren(ByVal comp As Component)
' List to keep track of components along with their suppressed status
Dim componentsWithStatus As New List(Of Tuple(Of Component, Boolean))
' List to keep track of processed component display names for duplicate check
Dim NameList As New List(Of String)
' Collect components and their suppressed status
For Each child As Component In comp.GetChildren()
' Add component and its suppressed status to the list
componentsWithStatus.Add(New Tuple(Of Component, Boolean)(child, child.IsSuppressed))
Next
' Sort the list so that suppressed components come first
componentsWithStatus.Sort(Function(x, y) y.Item2.CompareTo(x.Item2))
' Process sorted components
For Each tuple As Tuple(Of Component, Boolean) In componentsWithStatus
Dim child As Component = tuple.Item1
Dim isSuppressed As Boolean = tuple.Item2
' Check for duplicate part
If NameList.Contains(child.DisplayName()) Then
' Logic for handling duplicate parts
lw.WriteLine("Another duplicate, unworthy of my attention: " & child.DisplayName())
Continue For
Else
NameList.Add(child.DisplayName()) ' Add new component display name to the list
End If
If isSuppressed Then
lw.WriteLine("A suppressed component hides in the shadows: " & child.DisplayName())
Else
lw.WriteLine("-----------------")
' Retrieve and process the part associated with the child component
Dim childPart As Part = LoadComponentAndGetPart(child)
If childPart IsNot Nothing AndAlso childPart.IsFullyLoaded Then
' Display the part name instead of the component name
lw.WriteLine("Now, gaze upon the Part: " & childPart.Name)
ProcessBodies(childPart, child) ' Pass the Part and Component objects
Else
lw.WriteLine("This part lacks the magic it needs, it is not fully conjured.")
End If
If child.GetChildren.Length <> 0 Then
' Continue processing subassemblies
ReportComponentChildren(child)
End If
End If
Next
End Sub
' Method to load a component and return the associated part
Function LoadComponentAndGetPart(ByVal component As Component) As Part
Dim partLoadStatus As PartLoadStatus = Nothing
Try
' Set the work component to load the component
theSession.Parts.SetWorkComponent(component, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus)
' Get the part associated with the component
If TypeOf component.Prototype Is Part Then
Return CType(component.Prototype, Part)
End If
Catch ex As Exception
lw.WriteLine("An unexpected disturbance in the dark arts: " & ex.Message)
Return Nothing
Finally
' Dispose of the part load status
If partLoadStatus IsNot Nothing Then
partLoadStatus.Dispose()
End If
End Try
Return Nothing
End Function
Sub ProcessBodies(ByVal part As Part, ByVal comp As Component)
Dim nXObject1 As NXOpen.NXObject
Dim bbWidth, bbDepth, bbHeight, Length, Width, MaterialThickness As Double
Dim lengthDisplay As String = "" ' Declare lengthDisplay
Dim widthDisplay As String = "" ' Declare widthDisplay
' Set the measure manager to consistent unit
Dim myMeasure As MeasureManager = part.MeasureManager()
Dim wIconMOseT (0) As Unit
wIconMOseT (0) = part.UnitCollection.GetBase("Mass")
' Create a mass properties measurement for the entire part
Dim mb As MeasureBodies = myMeasure.NewMassProperties(wIconMOseT , 0.99, part.Bodies.ToArray())
mb.InformationUnit = MeasureBodies.AnalysisUnit.KilogramMilliMeter
' Check if the part is valid and loaded
If Not part Is Nothing AndAlso part.IsFullyLoaded Then
' Get the list of solid bodies in the part
Dim bodies As Body() = part.Bodies.ToArray()
' Lists to track bodies on Layer 1
Dim bodiesOnLayer1 As New List(Of Body)
' Check bodies and categorize based on layer
For Each body As Body In bodies
Dim bodyLayer As Integer = body.Layer
Dim bodyName As String = If(String.IsNullOrEmpty(body.Name), "Unnamed Body", body.Name)
If bodyLayer = 1 Then
bodiesOnLayer1.Add(body)
lw.WriteLine("Found Solid Body: " & bodyName & " on Layer 1")
lw.WriteLine(" ")
Else
lw.WriteLine("A mere illusion: " & bodyName & " on Layer " & bodyLayer.ToString())
lw.WriteLine("I shall disregard it.")
lw.WriteLine(" ")
End If
Next
' Check the number of bodies on Layer 1
If bodiesOnLayer1.Count > 1 Then
lw.WriteLine("Too many forms vie for attention on Layer 1")
lw.WriteLine("I shall choose none.")
lw.WriteLine(" ")
Exit Sub
ElseIf bodiesOnLayer1.Count = 1 Then
' Process the single body found on Layer 1
Dim bodyToProcess As Body = bodiesOnLayer1(0)
lw.WriteLine("Processing Body: " & bodyToProcess.Name)
Try
' Calculate and display the center of mass
Dim accValue(10) As Double
accValue(0) = 0.999
Dim massProps(46) As Double
Dim stats(12) As Double
theUFSession.Modl.AskMassProps3d(New Tag() {bodyToProcess.Tag}, 1, 1, 4, 0.03, 1, accValue, massProps, stats)
' Convert the center of mass coordinates to Double
Dim com_x As Double = massProps(3)
Dim com_y As Double = massProps(4)
Dim com_z As Double = massProps(5)
Dim toolingBoxBuilder1 As NXOpen.Features.ToolingBoxBuilder = workPart.Features.ToolingFeatureCollection.CreateToolingBoxBuilder(Nothing)
toolingBoxBuilder1.Type = NXOpen.Features.ToolingBoxBuilder.Types.BoundedBlock
toolingBoxBuilder1.ReferenceCsysType = NXOpen.Features.ToolingBoxBuilder.RefCsysType.SelectedCsys
toolingBoxBuilder1.XValue.SetFormula("10")
toolingBoxBuilder1.YValue.SetFormula("10")
toolingBoxBuilder1.ZValue.SetFormula("10")
toolingBoxBuilder1.OffsetPositiveX.SetFormula("0")
toolingBoxBuilder1.OffsetNegativeX.SetFormula("0")
toolingBoxBuilder1.OffsetPositiveY.SetFormula("0")
toolingBoxBuilder1.OffsetNegativeY.SetFormula("0")
toolingBoxBuilder1.OffsetPositiveZ.SetFormula("0")
toolingBoxBuilder1.OffsetNegativeZ.SetFormula("0")
toolingBoxBuilder1.RadialOffset.SetFormula("0")
toolingBoxBuilder1.Clearance.SetFormula("0")
toolingBoxBuilder1.CsysAssociative = True
toolingBoxBuilder1.NonAlignedMinimumBox = True
toolingBoxBuilder1.SingleOffset = False
Dim selectionIntentRuleOptions1 As NXOpen.SelectionIntentRuleOptions = Nothing
selectionIntentRuleOptions1 = workPart.ScRuleFactory.CreateRuleOptions()
selectionIntentRuleOptions1.SetSelectedFromInactive(False)
Dim selectedBody As NXOpen.Body = TryCast(NXOpen.Utilities.NXObjectManager.Get(bodyToProcess.Tag), NXOpen.Body)
If selectedBody Is Nothing Then
lw.WriteLine("The tag you dare present does not match any corporeal form.")
Return
End If
' Use the selectedBody for creating the dumb rule
Dim bodyDumbRule1 As NXOpen.BodyDumbRule = workPart.ScRuleFactory.CreateRuleBodyDumb(New Body() {selectedBody}, True, selectionIntentRuleOptions1)
selectionIntentRuleOptions1.Dispose()
Dim scCollector1 As NXOpen.ScCollector = toolingBoxBuilder1.BoundedObject
Dim rules1(0) As NXOpen.SelectionIntentRule
rules1(0) = bodyDumbRule1
scCollector1.ReplaceRules(rules1, False)
' Use the selectedBody in SetSelectedOccurrences
Dim selections1(0) As NXOpen.NXObject
selections1(0) = selectedBody
Dim deselections1(-1) As NXOpen.NXObject
toolingBoxBuilder1.SetSelectedOccurrences(selections1, deselections1)
Dim selectNXObjectList1 As NXOpen.SelectNXObjectList = Nothing
selectNXObjectList1 = toolingBoxBuilder1.FacetBodies
Dim objects1(-1) As NXOpen.NXObject
Dim added1 As Boolean = Nothing
added1 = selectNXObjectList1.Add(objects1)
toolingBoxBuilder1.CalculateBoxSize()
' Set the box position using the center of mass coordinates
Dim csysorigin1 As NXOpen.Point3d = New NXOpen.Point3d(com_x, com_y, com_z)
toolingBoxBuilder1.BoxPosition = csysorigin1
' Commit the tooling box to create the feature
nXObject1 = toolingBoxBuilder1.Commit()
' Destroy the tooling box builder
If toolingBoxBuilder1 IsNot Nothing Then
toolingBoxBuilder1.Destroy()
End If
' Access the body of the bounding box feature
Dim bboxFeature As Features.Feature = TryCast(nXObject1, Features.Feature)
Dim bboxBody As Body = Nothing
Dim innerBboxBody As Body = Nothing
If bboxFeature IsNot Nothing Then
For Each innerBboxBody In bboxFeature.GetBodies()
'bboxBody = body
Exit For
Next
End If
If innerBboxBody IsNot Nothing Then
' Initialize directions and distances arrays
Dim minCorner(2) As Double
Dim directions(,) As Double = New Double(2, 2) {}
Dim distances(2) As Double
' Get the bounding box of the body
theUFSession.Modl.AskBoundingBoxExact(innerBboxBody.Tag, Tag.Null, minCorner, directions, distances)
' Define the minimum corner point and print it
Dim cornerPoint As Point3d = New Point3d(minCorner(0), minCorner(1), minCorner(2))
' Initialize a List to store unique vertices
Dim vertices As New List(Of Point3d)()
' Iterate through all edges in the body and get vertices
For Each edge As Edge In innerBboxBody.GetEdges()
Dim vertex1 As Point3d, vertex2 As Point3d
edge.GetVertices(vertex1, vertex2)
If Not vertices.Contains(vertex1) Then vertices.Add(vertex1)
If Not vertices.Contains(vertex2) Then vertices.Add(vertex2)
Next
' Select the first vertex as the starting vertex
Dim startingVertex As Point3d = vertices(0)
' Initialize a List to store lengths of edges connected to the starting vertex
Dim edgeLengths As New List(Of Double)
Dim edgesAtStartingVertex As Integer = 0
If IsPointEqual(startingVertex, vertex1) OrElse IsPointEqual(startingVertex, vertex2) Then
edgesAtStartingVertex += 1
edgeLengths.Add(edge.GetLength())
End If
Next
' Check if we have at least three edges before accessing the list
If edgeLengths.Count >= 3 Then
' Sort the edge lengths
edgeLengths.Sort()
' Assign the sorted values
bbWidth = Math.Round(edgeLengths(0))
bbDepth = Math.Round(edgeLengths(1))
bbHeight = Math.Round(edgeLengths(2))
' Output the dimensions
lw.WriteLine("Bounding Box Dimensions:")
lw.WriteLine("Width: " & bbWidth.ToString("F0") & " mm")
lw.WriteLine("Depth: " & bbDepth.ToString("F0") & " mm")
lw.WriteLine("Height: " & bbHeight.ToString("F0") & " mm")
lw.WriteLine(" ")
Else
lw.WriteLine("Not enough edges found, like a spell half-cast.")
End If
' Valid material thicknesses
Dim validThicknesses As Double() = {2, 5, 7, 8, 8.5, 12, 12.5, 13, 22, 24, 25} ' Change here to suit your environment
Dim materialThicknessIdentified As Boolean = False
' Identify Material Thickness
If Array.IndexOf(validThicknesses, bbWidth) >= 0 Then
MaterialThickness = bbWidth
materialThicknessIdentified = True
ElseIf Array.IndexOf(validThicknesses, bbDepth) >= 0 Then
MaterialThickness = bbDepth
ElseIf Array.IndexOf(validThicknesses, bbHeight) >= 0 Then
MaterialThickness = bbHeight
End If
If Not materialThicknessIdentified Then
' Handle case where material thickness is not identified
MaterialThickness = Math.Min(bbWidth, Math.Min(bbDepth, bbHeight))
lw.WriteLine("Cannot identify material thickness. Using the smallest dimension instead.")
End If
' Determine Length and Width from the remaining dimensions
Dim remainingDimensions As New List(Of Double) From {bbWidth, bbDepth, bbHeight}
remainingDimensions.Remove(MaterialThickness)
' Ensure there are two dimensions left
If remainingDimensions.Count = 2 Then
' Assign the larger value to Length and the smaller to Width
Length = Math.Max(remainingDimensions(0), remainingDimensions(1))
Width = Math.Min(remainingDimensions(0), remainingDimensions(1))
Else
lw.WriteLine("Unable to determine Length and Width accurately.")
End If
' Delete the bounding box feature
Dim featureTags(0) As NXOpen.Tag
featureTags(0) = bboxFeature.Tag
theUFSession.Modl.DeleteFeature(featureTags)
Dim myForm As New Form1()
If myForm.ShowDialog() = DialogResult.OK Then
' Check the IsGrainDirectionChanged property
If myForm.IsGrainDirectionChanged Then
' Flip Length and Width
Dim temp As Double = Length
Length = Width
Width = temp
lw.WriteLine("Grain direction changed")
End If
' Update Length and Width based on LengthExtra and WidthExtra
lengthDisplay = Length.ToString("F0")
If myForm.LengthExtra > 0 Then
Length += myForm.LengthExtra
lengthDisplay = Length.ToString("F0") & " (" & myForm.LengthExtra.ToString("F0") & ")"
Else
'lw.WriteLine("No Extra added to Length")
End If
widthDisplay = Width.ToString("F0")
If myForm.WidthExtra > 0 Then
Width += myForm.WidthExtra
widthDisplay = Width.ToString("F0") & " (" & myForm.WidthExtra.ToString("F0") & ")"
Else
'lw.WriteLine("No Extra added to Width")
End If
' Write the updated dimensions to the listing window
If Length > 0 And Width > 0 Then
lw.WriteLine("Length: " & lengthDisplay & " mm")
lw.WriteLine("Width: " & widthDisplay & " mm")
Else
lw.WriteLine("The dimensions evade my grasp.")
End If
End If
' Adjust Material Thickness if necessary - Change here to suit your environment
Select Case MaterialThickness
Case 8.5
MaterialThickness = 8
lw.WriteLine("Material thickness identified: 8.5mm. Changed to 8mm.")
Case 12.5
MaterialThickness = 12
lw.WriteLine("Material thickness identified: 12.5mm. Changed to 12mm.")
Case 22
MaterialThickness = 20
lw.WriteLine("Material thickness identified: 22mm. Changed to 20mm.")
Case 25
MaterialThickness = 24
lw.WriteLine("Material thickness identified: 25mm. Changed to 24mm.")
End Select
lw.WriteLine("Material Thickness: " & MaterialThickness.ToString("F0") & " mm")
lw.WriteLine(" ")
' Adding Attributes to the Component as Part - Change here to suit your environment
AddPartAttribute(comp, "VLength", lengthDisplay)
lw.WriteLine("Length attribute added")
AddPartAttribute(comp, "VWidth", widthDisplay)
lw.WriteLine("Width attribute added")
AddPartAttribute(comp, "VMaterialThickness", MaterialThickness)
lw.WriteLine("Material Thickness attribute added")
Else
lw.WriteLine("The bounding box, a ghost, it eludes me.")
End If
lw.WriteLine("An error? A mere setback in my grand design: " & ex.Message)
Finally
End Try
Else
lw.WriteLine("No solid bodies found on Layer 1")
End If
Else
lw.WriteLine("The part before me is flawed, incomplete in its essence.")
End If
End Sub
Function IsPointEqual(point1 As Point3d, point2 As Point3d) As Boolean
Const Tolerance As Double = 0.001
Return (Math.Abs(point1.X - point2.X) < Tolerance AndAlso
Math.Abs(point1.Y - point2.Y) < Tolerance AndAlso
Math.Abs(point1.Z - point2.Z) < Tolerance)
End Function
' Method to reset to the main assembly
Sub ResetToMainAssembly()
Dim partLoadStatus2 As PartLoadStatus = Nothing
Try
theSession.Parts.SetWorkComponent(Nothing, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus2)
lw.WriteLine(" ")
lw.WriteLine("As shadows gather and night befalls, our paths now diverge in silent halls.")
lw.WriteLine("Remember, the Dark Lord's gaze, ever so watchful, in mystery's maze. ")
lw.WriteLine("Until we meet in destiny's corridors, obscure and deep,")
lw.WriteLine("our dark voyage concludes, in secrets we keep.")
lw.WriteLine(" ")
lw.WriteLine("Failed to return to my dominion: " & ex.Message)
Finally
' Dispose the PartLoadStatus object if it's not null
If partLoadStatus2 IsNot Nothing Then
partLoadStatus2.Dispose()
End If
End Try
End Sub
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Form1
Inherits System.Windows.Forms.Form
Public Property LengthExtra As Double
Public Property WidthExtra As Double
Public Property IsGrainDirectionChanged As Boolean
' Form designer variables
Private components As System.ComponentModel.IContainer
Friend WithEvents chkChangeGrainDirection As System.Windows.Forms.CheckBox
Friend WithEvents txtExtraLength As System.Windows.Forms.TextBox
Friend WithEvents txtExtraWidth As System.Windows.Forms.TextBox
Friend WithEvents btnOK As System.Windows.Forms.Button
'Friend WithEvents btnCancel As System.Windows.Forms.Button
Friend WithEvents lblExtraLength As System.Windows.Forms.Label
Friend WithEvents lblExtraWidth As System.Windows.Forms.Label
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing AndAlso components IsNot Nothing Then
components.Dispose()
End If
MyBase.Dispose(disposing)
End Sub
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub Form1_Load(sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Me.StartPosition = FormStartPosition.Manual
Me.Location = New System.Drawing.Point(winFormLocationX, winFormLocationY)
' Setting the color properties of the form and its controls
Me.BackColor = Color.FromArgb(55, 55, 55) ' Set form background color
' Set colors for buttons
btnOK.BackColor = Color.FromArgb(50, 50, 50)
'btnCancel.BackColor = Color.FromArgb(50, 50, 50)
' Setting the font colors to white
txtExtraLength.ForeColor = Color.Black
txtExtraWidth.ForeColor = Color.Black
btnOK.ForeColor = Color.White
'btnCancel.ForeColor = Color.White
lblExtraLength.ForeColor = Color.White
lblExtraWidth.ForeColor = Color.White
chkChangeGrainDirection.ForeColor = Color.White
End Sub
Private Sub Form1_FormClosing(sender As Object, e As FormClosingEventArgs) Handles Me.FormClosing
' Save the location of the form
winFormLocationX = Me.Location.X
winFormLocationY = Me.Location.Y
End Sub
Private Sub InitializeComponent()
Me.chkChangeGrainDirection = New System.Windows.Forms.CheckBox()
Me.txtExtraLength = New System.Windows.Forms.TextBox()
Me.txtExtraWidth = New System.Windows.Forms.TextBox()
Me.btnOK = New System.Windows.Forms.Button()
'Me.btnCancel = New System.Windows.Forms.Button()
Me.lblExtraLength = New System.Windows.Forms.Label()
Me.lblExtraWidth = New System.Windows.Forms.Label()
Me.SuspendLayout()
'chkChangeGrainDirection
Me.chkChangeGrainDirection.AutoSize = True
Me.chkChangeGrainDirection.Location = New System.Drawing.Point(30, 17)
Me.chkChangeGrainDirection.Name = "chkChangeGrainDirection"
Me.chkChangeGrainDirection.Size = New System.Drawing.Size(200, 17)
Me.chkChangeGrainDirection.TabIndex = 0
Me.chkChangeGrainDirection.Text = "Would you like to change Grain Direction?"
Me.chkChangeGrainDirection.UseVisualStyleBackColor = True
'lblExtraLength
Me.lblExtraLength.AutoSize = True
Me.lblExtraLength.Location = New System.Drawing.Point(30, 55)
Me.lblExtraLength.Name = "lblExtraLength"
Me.lblExtraLength.Size = New System.Drawing.Size(100, 13)
Me.lblExtraLength.Text = "Enter Extra Length:"
'txtExtraLength
Me.txtExtraLength.Location = New System.Drawing.Point(220, 50)
Me.txtExtraLength.Name = "txtExtraLength"
Me.txtExtraLength.Size = New System.Drawing.Size(100, 20)
Me.txtExtraLength.TabIndex = 1
'lblExtraWidth
Me.lblExtraWidth.AutoSize = True
Me.lblExtraWidth.Location = New System.Drawing.Point(30, 85)
Me.lblExtraWidth.Name = "lblExtraWidth"
Me.lblExtraWidth.Size = New System.Drawing.Size(100, 13)
Me.lblExtraWidth.Text = "Enter Extra Width:"
'txtExtraWidth
Me.txtExtraWidth.Location = New System.Drawing.Point(220, 80)
Me.txtExtraWidth.Name = "txtExtraWidth"
Me.txtExtraWidth.Size = New System.Drawing.Size(100, 20)
Me.txtExtraWidth.TabIndex = 2
'btnOK
Me.btnOK.Location = New System.Drawing.Point(152, 130)
Me.btnOK.Name = "btnOK"
Me.btnOK.Size = New System.Drawing.Size(75, 23)
Me.btnOK.TabIndex = 3
Me.btnOK.Text = "OK"
Me.btnOK.UseVisualStyleBackColor = True
'btnCancel
'Me.btnCancel.Location = New System.Drawing.Point(220, 130)
'Me.btnCancel.Name = "btnCancel"
'Me.btnCancel.Size = New System.Drawing.Size(75, 23)
'Me.btnCancel.TabIndex = 4
'Me.btnCancel.Text = "Quit"
'Me.btnCancel.UseVisualStyleBackColor = True
'Form1
Me.AcceptButton = Me.btnOK
'Me.CancelButton = Me.btnCancel
Me.ClientSize = New System.Drawing.Size(380, 170)
Me.Controls.Add(Me.chkChangeGrainDirection)
Me.Controls.Add(Me.lblExtraLength)
Me.Controls.Add(Me.txtExtraLength)
Me.Controls.Add(Me.lblExtraWidth)
Me.Controls.Add(Me.txtExtraWidth)
Me.Controls.Add(Me.btnOK)
'Me.Controls.Add(Me.btnCancel)
Me.Name = "Form1"
Me.Text = "Dimensions"
Me.ResumeLayout(False)
Me.PerformLayout()
End Sub
Private Sub btnOK_Click(sender As Object, e As EventArgs) Handles btnOK.Click
' Set the IsGrainDirectionChanged based on the checkbox
Me.IsGrainDirectionChanged = chkChangeGrainDirection.Checked
' Set the properties based on user input
If chkChangeGrainDirection.Checked Then
Me.IsGrainDirectionChanged = True
End If
Dim lengthExtraValue As Double
Dim widthExtraValue As Double
' Validate and set LengthExtra
If Not String.IsNullOrWhiteSpace(txtExtraLength.Text) AndAlso Double.TryParse(txtExtraLength.Text, lengthExtraValue) Then
Me.LengthExtra = lengthExtraValue
ElseIf Not String.IsNullOrWhiteSpace(txtExtraLength.Text) Then
MessageBox.Show("Enter a proper lenght number worthy of my time. ", "Input Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
Return
End If
' Validate and set WidthExtra
If Not String.IsNullOrWhiteSpace(txtExtraWidth.Text) AndAlso Double.TryParse(txtExtraWidth.Text, widthExtraValue) Then
Me.WidthExtra = widthExtraValue
ElseIf Not String.IsNullOrWhiteSpace(txtExtraWidth.Text) Then
MessageBox.Show("Enter a proper width number worthy of my time. ", "Input Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
Return
End If
Me.DialogResult = DialogResult.OK
Me.Close()
End Sub
End Class
Sub AddPartAttribute(ByVal comp As Component, ByVal attTitle As String, ByVal attValue As String)
If comp Is Nothing Then
lw.WriteLine("A null component? Unacceptable!")
Exit Sub
End If
Try
Dim objects1(0) As NXObject
objects1(0) = comp
Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(workPart, objects1, AttributePropertiesBuilder.OperationType.None)
attributePropertiesBuilder1.IsArray = False
attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
attributePropertiesBuilder1.ObjectPicker = AttributePropertiesBaseBuilder.ObjectOptions.ComponentAsPartAttribute
attributePropertiesBuilder1.Title = attTitle
attributePropertiesBuilder1.StringValue = attValue
Dim nXObject1 As NXObject
nXObject1 = attributePropertiesBuilder1.Commit()
attributePropertiesBuilder1.Destroy()
lw.WriteLine("A flaw in the enchantment: " & ex.Message)
End Try
End Sub
Public Function GetUnloadOption(dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
