jeremypw
- Oct 14, 2014
- 4
I'm designing a circuit that will control turning on/off two rotating emergency lights. The specs for the rotating lights are linked below. Should I include a fuse in my design and how do I select the proper fuse? I want to ensure that the circuit is is safe to have in the home and it won't cause a fire or shock anyone.
Brief Description of Circuit:
Arduino with IR receiver will switch on the AC power source through a relay that will provide power to the two lights in parallel. If a fuse is recommended it will be connected to the phase side of the power source before the relay.
Rotating Warning Light
