BZLAM21
Petroleum
- Aug 12, 2020
- 61
HI,
We plan to Install a Gas Turbine but The temperature and humidity of the outside air vary depending on the date and time and can reach the following values:
Relative humidity 72%
Maximum ambient temperature 47 c°
The question that arises is the following:
Is the performance of the turbine better if we choose 38c° for the design Dry bulb design temperature for Gas Turbine Generators ?
Any ideas or suggestions you might have would be helpful.
BEST REGARS.
BEST REGARS.
