Gasket source
murphystout
Materials
Aug 8, 2008
5
Hi, I'm new here.
Does anyone know a good source for gaskets? I guess I could google it, but I'd like to get some suggestions from people "in the know", so to speak.
Thanks in advance for your responses.
murphystout,
When I need custom gaskets, I generate drawings and I contact local rubber vendors. They cut stuff out for me, and so far, I am happy with the results. Custom cut gaskets are cheap.
My rubber requirements are usually that the rubber is available. If you have exotic requirements, you will have to research and Google.
JHG
We buy custom gaskets from a local vender. They're cheap IF it's a standard materials; high-temperature or chemical-resistant gaskets can be expensive.
Ditto on buying gaskets from a local source. ThomasNet is your friend...
Thanks a lot for your help guys...
Just curious, how significant is the price difference?
murphystout,
The price difference between what? There is not necessarily an alternative to a custom gasket. Making an off-the-shelf part work could rack up a lot more design time.
JHG
Very true, I see what your saying.
I'll contact some custom vendors and see what the prices are like.
Thanks again!
Lamons Gasket is a good source manufacturer for all types styles and different material gaskets. They are headquartered in Houston, TX but have branches all across the U.S. that have local manufacturing facilities.
 http://www.lamonsgasket.com
billhi
You wouldn't happen to work for Lamons, would you?
As a long-time reader of these forums, it's usually suspicious when someone comes on, makes one reply in a thread that is several months old, and that reply promotes a particular manufacturer.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
