Gator Bar 2
BSVBD
463
Has anyone specified or used Gator Bar?
With the current rising prices of steel, our primary General Contractor is inquiring about the use of Gator Bar, a Fiber-Reinforced Polymer (FRP) Rebar for use as mesh in flatwork and horizontal rebar in non-load bearing frost walls and footings.
Rust-free, Higher Tensile Strength, Lightweight, stays centered in thickness of slab.
Brief internet research shows that Neuvokas has been the primary producer since 2016.
Comments? Advice? Endorsements? Cautions?
Thank you!
Its stiffness is a quarter of steel. Cracks will be wider since it sounds like you're using it for crack control reo. But a lot of crack control steel isn't doing much either.
Why doesn't the steel reo stay in place?
I took a FRP class in graduate school. It is awesome stuff, but the stiffness issue is the Achilles heel.
We often found that you have to design for serviceability issues like deflection/cracking FIRST; and then check for the ultimate loading conditions.
Carbon bars have higher stiffness but I guess they aren't as cheap as I've never had one proposed as an alternative and there seems to be fewer sellers.
I like how under-reinforced design is drilled into us, only for over-reinforced to be perfectly acceptable when there's a new product to flog.
I design a lot with FRP reinforcing. See attached thread concerning Gatorbar. I had provided my opinion on the product.
Link
