Hello All,
I am currently working on several rubber components produced via the molding process and would appreciate your guidance on the general tolerance requirements for angular dimensions in such parts.
Could you please confirm if the tolerance table provided (referenced in the attached image) includes the tolerance limits for angular dimensions, similar to how ISO 2768-m outlines general tolerances for linear dimensions and angular dimension? If yes how it is controlled and what is shorter side and larger side of the angle.
