cayrick
- Aug 25, 2021
- 5
Insights please, on an air cooled mobile Honda Generator (5kw) housed in a weatherproof concrete and metal box ( new installation)
. Installed in a temperate climate, with an average ambient temperature range of between 68F-85F year round. I installed a small vent fan of approx 850 cfm. Most small generator mfrs. do not publish operating environment temperature limit info, presumably because they do not want generators installed in compartments, and so if they have info, they intentionally withold it. Published info might also become problematic if there are warranty issues. I have installed a propane conversion kit and run it on propane only rather than gas. My concern recently, while running it for over an hour, the compartment interior reached an equilibrium delta T of 50 deg F under load. In other words the outside temp. was 75 F and the interior of the compartment reached 125 F.
In my mind this set off alarm bells as I am concerned about alternator and engine damage. I am looking for insights from people who have more knowledge than myself in this area. Similar installations are commonly found in Youtube videos where people showcase their personal generator installations in plastic garden sheds. These are done typically by folks with a limited technical background and nobody ever talks about or considers interior operating temperatures to be an issue, and operate on the principle "if it ain't broke don't fix it". Should I be looking at a larger capacity fan? What delta T should I be shooting for?
