I wonder if anyone really understands how Geometry Pattern works. Does it work? Here is my problem. I am working on a 50 position connector and would like to draw one position to completion, then pattern it. Of course I can't do it this way! Anyone know why? Because you can't pattern things like up to surface without getting something you really don't want. You can't Pattern Chamfers! You can't always pattern radii. I bet solidworks VAR never mentioned that during pre sales chat. Anyhow enough of my rant back to Geometry Pattern. It is my impression that geometry pattern should be the same as if I were to select all of the faces of the feature(s) and then knit them to one, then pattern. In fact that is what I finally did after hours on the phone with my VAR. Even he can't explain Geometry Pattern. (Please don't give me the same crap thats in the help file.)
Please if anyone agrees that Geometry Pattern does not work, or that we should have the abilty to pattern everything, please sumitt an enhancement request. (Although I think it should be a bug report that Geometry Pattern doesn't work.)
