Get angle
theing
New member
Mar 5, 2014
18
0
0
MX
hi everybody, i am new in this, and i am learning,
i need to get the angles of a surface, i have the following code
Sub catmain()
Set objsel = CATIA.ActiveDocument.Selection
objsel.Clear
objsel.Search "Type=Topology.Face,all"
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set Selection = partDocument1.Selection
Set ref1 = Selection.Item(1).Reference
Set spabench = partDocument1.GetWorkbench("SPAWorkbench")
Set mymeas = spabench.GetMeasurable(ref1)
On Error Resume Next
Angle = mymeas.Angle
MsgBox Angulo
End Sub
the msgbox is empty, and i dont know what am i doing wrong,
i hope anyone can help me out with this,
Thank you for taking the time reading this.
hi ferdo, thank you so much for taking the time reading my issue,
i already change the msgbox and still giving me nothing,
and i search for all the faces because i thought that the faces needed to be count previously,
never mind i just did it, the thing is that is no giving me anything with surface, i dont know is that the way it should be, but it is giving me an angle with an edge, so i guess i will have to evaluate the edges, here is the code i have:
Sub catmain()
Set ref1 = objsel.Item(1).Reference
MsgBox Angle
End Sub
Of course
Code:
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Clear
Dim InputObjectType(0), Status1
InputObjectType(0)="Edge"
Status1=selection1.SelectElement2(InputObjectType,"Select 1st Edge",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
Dim reference1 As Reference
Set reference1 = selection1.Item(1).Reference
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = productDocument1.GetWorkbench("SPAWorkbench")
Dim TheMeasureable
Set TheMeasureable = TheSPAWorkbench.GetMeasurable(reference1)
selection1.Clear
Status1=selection1.SelectElement2(InputObjectType,"Select 2nd Edge",false)
Dim reference2 As Reference
Set reference2 = selection1.Item(1).Reference
msgbox TheMeasureable.GetAngleBetween(reference2)
End Sub
Fernando
