Get Component Rotation Angles 4
ramakrishna90589
Automotive
IN
Hi All,
i have an assembly and i want collect component rotation angles about X, Y & Z.
i searched for this in Eng-tips forum and i got following code to get component rotation matrix.
Code:
Dim RotMat as Matrix3x3
Dim child As Component
Dim LW As ListingWindow = theSession.ListingWindow
LW.Open()
child.GetPosition(pt, RotMat)
        lw.WriteLine ( "|" & child.displayname() & "," & _
"" & pt.x & ", " & pt.y & ", " & pt.z & "," & _
"" & "" & _
RotMat.xx & ", " & RotMat.yx & ", " & RotMat.zx & "," & _
RotMat.xy & ", " & RotMat.yy & ", " & RotMat.zy & "," & _
RotMat.xz & ", " & RotMat.yz & ", " & RotMat.zz )
and i want to is there any way to get component angles rather than rotation matrix.
Thanks in Advance.
Thanks for the quick reply. Is there a way to get this [X=6.52,Y=10.35,Z=0.625] which is the result from your journal to look like this X6.52 Y10.35 Z0.625 . No Brackets, commas or equals signs. Thanks
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim myComponents() As TaggedObject
        If SelectComponents("Select components", myComponents) = Selection.Response.Cancel Then
            Return
        End If
        For Each tempComp As Component In myComponents
            lw.WriteLine(tempComp.Name)
            Dim rotX As Double      'rotation about X axis
            Dim rotY As Double      'rotation about Y axis
            Dim rotZ As Double      'rotation about Z axis
            Dim compPt As Point3d = CompPos(tempComp)
            CompRot(tempComp, rotX, rotY, rotZ)
            lw.WriteLine(" rotation about X axis: " & rotX)
            lw.WriteLine(" rotation about Y axis: " & rotY)
            lw.WriteLine(" rotation about Z axis: " & rotZ)
            lw.WriteLine(" X" & compPt.X.ToString & " Y" & compPt.Y.ToString & " Z" & compPt.Z.ToString)
            lw.WriteLine("")
        Next
    End Sub
    Function SelectComponents(ByVal prompt As String, ByRef selObj() As TaggedObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select components"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_component_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj)
        If resp = Selection.Response.Ok Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Sub CompRot(ByVal someComponent As Component, ByRef RX1 As Double, ByRef RY1 As Double, ByRef RZ1 As Double)
        'extract euler angles from rotation matrix:
        '[URL unfurl="true"]https://d3cw3dd2w32x2b.cloudfront.net/wp-content/uploads/2012/07/euler-angles.pdf[/URL]
        Dim pt As Point3d
        Dim RotMat As Matrix3x3
        someComponent.GetPosition(pt, RotMat)
        Dim c1, c2, s1 As Double
        RX1 = Math.Atan2(RotMat.Yz, RotMat.Zz)
        c2 = Math.Sqrt(RotMat.Xx ^ 2 + RotMat.Xy ^ 2)
        RY1 = Math.Atan2(-RotMat.Xz, c2)
        s1 = Math.Sin(RX1)
        c1 = Math.Cos(RX1)
        RZ1 = Math.Atan2(s1 * RotMat.Zx - c1 * RotMat.Yx, c1 * RotMat.Yy - s1 * RotMat.Zy)
        'convert angles from radians to degrees
        RX1 *= (180 / Math.PI)
        RY1 *= (180 / Math.PI)
        RZ1 *= (180 / Math.PI)
    End Sub
    Function CompPos(ByVal someComponent As Component) As Point3d
        Dim pt As Point3d
        Return pt
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
I have revised the journal file to create a separate file for each component. Is it possible if there are identical components to send that group to a file. For example component1 has 3 locations which would get written to file 1 and component2 has only 1 location which would get written to file 2. Thanks
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Public s As Session = Session.GetSession()
    Sub Main()
        Dim workPart As Part = s.Parts.Work
        Dim wpName As String = workPart.FullPath.ToString()
        Dim textFileName As String = Nothing
            Return
        End If
            textFileName = "C:\temp\" & tempComp.Name & ".NC"
            Dim outFile As IO.StreamWriter
            outFile = My.Computer.FileSystem.OpenTextFileWriter(textFileName, _
        False)
            outFile.AutoFlush = True
            outFile.WriteLine("/" & wpname)
            rotZ = rotZ + 180
            outFile.WriteLine()
            outFile.WriteLine("/" & tempComp.Name)
            outFile.WriteLine("X" & compPt.X.ToString("F4") & " Y" & compPt.Y.ToString("F4") & " Z" & compPt.Z.ToString("F4") & " C" & rotZ.ToString("F4"))
            outFile.Close()
            'MsgBox("Text File Name: " & textFileName, MsgBoxStyle.Information)
        Next
    End Sub
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects(prompt, _
         selobj)
        Else
        End If
    End Function
        Dim pt As Point3d
        s1 = Math.Sin(RX1)
        c1 = Math.Cos(RX1)
    End Sub
        Dim pt As Point3d
        Return pt
    End Function
    End Function
End Module
I'd suggest using the .AppendText method of the stream writer; see for some example code.
Also, I noticed that you are using the component's .Name property. This will return the custom name assigned by the user; it is possible that 2 identical components have different names. This might never be an issue for you, but if it is, you may want to look into using the .DisplayName or some other mechanism to ensure you are grouping components properly.
Thanks. I think I will go through the list of chosen components and create the files. Then I will go through the list of components again and append the information to the existing files.
You should be able to use the Append mode and go through the components just once. If the file doesn't exist, Append mode will create it; if it does exist, it will append to it.
I found a good example on the Microsoft webpage for appending files. Thanks. Do you know where I can look at a sample for manipulating strings. I have strings like this 1234abcd1 and 1234abcd10 sometimes the text in between is longer. I need to end up with just the right end number 1 and 10. Thanks
In the above NX journal is there a way to filter the selection of components to supply me with only the unique components. I am looking for a way to append text only once to the bottom of each file I created.
If you have multiples of a component, each one can be positioned independently. You only need the position of 1?
If so, my first thought would be to keep a list of component names; if the list contains the component name, skip it - otherwise write the info to your file then add the component name to the list.
Code:
dim compList as new list (of string)
'process components
for each myComp in componentCollection
  if not compList.contains(myComp.name) then
    write info to file
    compList.add(myComp.name)
  end if
next
I needed the positions of all of the components. For example Part 4 had 6 locations which were appended to the file. At the end of the file I needed to add some NC code but only once not one time for every part location. So I had it go through the components one more time leaving out the duplicate parts just to add the NC code. Everything worked out great. Thanks for the help on this project.
Is it possible to get XYZ values of a named point within a component just by selecting the component as we do in the above journals.
It is possible. Are you looking for a named point object, or a named point feature?
Something like this?
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
        Dim theComponent As Assemblies.Component
        If SelectComponent("Select a component", theComponent) = Selection.Response.Cancel Then
            Exit Sub
        End If
        Const dumbPointName As String = "DUMB_POINT"
        Const featurePointName As String = "FEATURE_POINT"
        Dim thePart As Part = theComponent.Prototype.OwningPart
        For Each temp As Point In thePart.Points
            If temp.Name = dumbPointName Then
                lw.WriteLine(dumbPointName & " found, location: " & temp.Coordinates.ToString)
            End If
        Next
        For Each temp As Features.Feature In thePart.Features
            If temp.FeatureType = "POINT" Then
                If temp.Name = featurePointName Then
                    Dim thePoint As Point = temp.GetEntities(0)
                    lw.WriteLine(featurePointName & " found, location: " & thePoint.Coordinates.ToString)
                End If
            End If
        Next
        lw.Close()
    End Sub
    Function SelectComponent(ByVal prompt As String, ByRef myComp As Assemblies.Component) As Selection.Response
        Dim selObj As TaggedObject
        Dim title As String = "Select a component"
        Dim cursor As Point3d
            .Subtype = UFConstants.UF_all_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            myComp = selObj
        Else
        End If
    End Function
    End Function
End Module
I am trying to get a location of a named 3D point per component. Also I am trying to make this work with the above journal. Thanks
In the original journal that we created I pick the component and it writes a file with the xyz and rotation angles. Consider this as the finish location of the component. I want to add start location for the component within the same journal. The start location of the component would be straight up in the +Z direction an amount ex. Z1.0 or in a direction based on an amount and a given angle which would modify the xyz values. I need all of this to write to the file all at the same time. I thought that if we just created a point in the component we could report on the component(finish location) and its point(start location) at the same time but the journal you gave me recently doesn't seen to mesh well with the one we created earlier. Any help would be greatly appreciated. Thank-you very much.
If all you need is the component start position, that's easy:
pt: (0,0,0)
0° rotation about X axis
0° rotation about Y axis
0° rotation about Z axis
wasn't really what I was looking for. How about this? Can I read attributes from a component and have them set to variables in my journal?
