Get Component Rotation Angles 4
ramakrishna90589
Automotive
IN
Hi All,
i have an assembly and i want collect component rotation angles about X, Y & Z.
i searched for this in Eng-tips forum and i got following code to get component rotation matrix.
Code:
Dim RotMat as Matrix3x3
Dim child As Component
Dim LW As ListingWindow = theSession.ListingWindow
LW.Open()
child.GetPosition(pt, RotMat)
        lw.WriteLine ( "|" & child.displayname() & "," & _
"" & pt.x & ", " & pt.y & ", " & pt.z & "," & _
"" & "" & _
RotMat.xx & ", " & RotMat.yx & ", " & RotMat.zx & "," & _
RotMat.xy & ", " & RotMat.yy & ", " & RotMat.zy & "," & _
RotMat.xz & ", " & RotMat.yz & ", " & RotMat.zz )
and i want to is there any way to get component angles rather than rotation matrix.
Thanks in Advance.
This is what I was trying to figure out before. For a group of selected components in an assembly I would like to be able to get a location for a named point. The location being within the assembly. Right now the area highlighted in yellow gets me the location of the point relative to the owning components csys. Could you help me try to maintain the structure of the code that is not highlighted and modify the yellow highlighted code to achieve this. Thanks
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.IO
Imports System.Collections.Generic
Module Module1
    Public s As Session = Session.GetSession()
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = s.Parts.Work
        Dim wpName As String = workPart.FullPath.ToString()
        Dim textFileName As String = Nothing
        Dim myComponents() As TaggedObject
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        If SelectComponents("Select components", myComponents) = Selection.Response.Cancel Then
            Return
        End If
        [highlight #FCE94F]For Each tempComp As Component In myComponents
        Dim thePart As Part = tempcomp.Prototype.OwningPart
        Const dumbPointName As String = "DUMB_POINT"
        Const featurePointName As String = "FEATURE_POINT"
        For Each temp As Point In thePart.Points
            'If temp.Name = dumbPointName Then
            lw.WriteLine(dumbPointName & " found, location: " & temp.Coordinates.ToString)
            'End If
       Next[/highlight]
        lw.Close()
       End Sub
    Function SelectComponents(ByVal prompt As String, ByRef selObj() As TaggedObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select components"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_component_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj)
        If resp = Selection.Response.Ok Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
End Module
Once you find the point of interest, you need to convert it from "component space" to "assembly space"; search the API reference for the MapPoint function to get headed in the right direction.
www.nxjournaling.com
I found an example of Mappoint but it keeps returning the same values. Do you have any examples for "component space" to "assembly Space" This is the example I found.
Code:
'function taken from GTAC example
Function Abs2WCS(ByVal inPt As Point3d) As Point3d
	Dim pt1(2), pt2(2) As Double
	pt1(0) = inPt.X
	pt1(1) = inPt.Y
	pt1(2) = inPt.Z
	ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_COORDS, pt1, UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt2)
	Abs2WCS.X = pt2(0)
	Abs2WCS.Y = pt2(1)
	Abs2WCS.Z = pt2(2)
End Function
The below code is a modification of my last code post; it will report the location of a dumb point in the part space and the assembly space (absolute csys).
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
        Dim theComponent As Assemblies.Component
        If SelectComponent("Select a component", theComponent) = Selection.Response.Cancel Then
            Exit Sub
        End If
        Dim thePart As Part = theComponent.Prototype.OwningPart
                lw.WriteLine(dumbPointName & " found, location in part: " & temp.Coordinates.ToString)
                Dim pointLoc() As Double = {temp.Coordinates.X, temp.Coordinates.Y, temp.Coordinates.Z}
                'make component the work part
                Dim markId1 As Session.UndoMarkId
                markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Make Work Part")
                Dim partLoadStatus1 As PartLoadStatus
                theSession.Parts.SetWorkComponent(theComponent, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus1)
                workPart = theSession.Parts.Work
                partLoadStatus1.Dispose()
                'map point from component to assembly
                theUfSession.Csys.MapPoint(UFConstants.UF_CSYS_WORK_COORDS, pointLoc, UFConstants.UF_CSYS_ROOT_COORDS, pointLoc)
                lw.WriteLine("location in assembly ACS: " & pointLoc(0) & ", " & pointLoc(1) & ", " & pointLoc(2))
                lw.WriteLine("")
                'make assembly the work part
                Dim markId2 As Session.UndoMarkId
                markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Make Work Part")
                Dim nullAssemblies_Component As Assemblies.Component = Nothing
                Dim partLoadStatus2 As PartLoadStatus
                theSession.Parts.SetWorkComponent(nullAssemblies_Component, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus2)
                partLoadStatus2.Dispose()
            End If
        Next
        For Each temp As Features.Feature In thePart.Features
            If temp.FeatureType = "POINT" Then
                If temp.Name = featurePointName Then
                    Dim thePoint As Point = temp.GetEntities(0)
                    lw.WriteLine(featurePointName & " found, location: " & thePoint.Coordinates.ToString)
                End If
            End If
        Next
        lw.Close()
    End Sub
    Function SelectComponent(ByVal prompt As String, ByRef myComp As Assemblies.Component) As Selection.Response
        Dim selObj As TaggedObject
        Dim title As String = "Select a component"
        Dim cursor As Point3d
            .Subtype = UFConstants.UF_all_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            myComp = selObj
        Else
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
