Get Minimun Distance 1
lapek
Aerospace
Aug 26, 2013
37
hi everybody
i have an issue, hope you can help me with this
well i have a product with abot 130 parts, and i need to know the distance between each part,
doing it manually is terrible, hope you can help me with this,
thank you
You can go in assembly design and use the clash analysis function.
As you are not looking off clash but distance, select the option with clearance and put the parameter to a large number. Also select option Between all components so it will check each part against all.
download.aspx
Eric N.
hi itsmyjob, thats a great idea,
thank you so much for your answer
is there any way to do it in a macro?
Code:
Private Function MeasureClash(MaxClearance As Double) As Double
    Dim MyDoc As Document
    Set MyDoc = CATIA.ActiveDocument
    Dim MyProduct As Product
    Set MyProduct = MyDoc.Product
    Dim Product1 As Product
    Dim Product2 As Product
    Set Product1 = MyProduct.Products.Item("Part1.1")
    Set Product2 = MyProduct.Products.Item("Part2.1")
    Dim MySelection As Selection
    Set MySelection = MyDoc.Selection
    MySelection.Clear
    Call MySelection.Add(Product1)
    Call MySelection.Add(Product2)
    Dim cClashes As Clashes
    Set cClashes = MyProduct.GetTechnologicalObject("Clashes")
    Dim MyClash As Clash
    Set MyClash = cClashes.AddFromSel
    MyClash.ComputationType = catClashComputationTypeInsideOne
    If MaxClearance > 0 Then
        MyClash.InterferenceType = catClashInterferenceTypeClearance
        MyClash.Clearance = MaxClearance
    Else
       MyClash.InterferenceType = catClashInterferenceTypeContact
    End If
    MyClash.Compute
    MySelection.Clear
    Dim i As Integer
    If MyClash.Conflicts.Count <> 0 Then
        For i = 1 To MyClash.Conflicts.Count
            Dim MyConflict As Conflict
            Set MyConflict = MyClash.Conflicts.Item(i)
            If MyConflict.Type = catConflictTypeClash Then
                MeasureClash = MyConflict.Value
            End If
            If MyConflict.Type = catConflictTypeClearance Then
            End If
            If MyConflict.Type = catConflictTypeContact Then
            End If
        Next
    Else
        MsgBox "Clearance Value > " + CStr(MaxClearance)
        MeasureClash = 3333
    End If
End Function
Private Function MeasureDistance() As Double
    MySelection.Clear
    Dim cDistances As Distances
    Set cDistances = MyProduct.GetTechnologicalObject("Distances")
    Dim MyDistance As Distance
    Set MyDistance = cDistances.AddFromSel
    MyDistance.ComputationType = catDistanceComputationTypeInsideOne
    MyDistance.MeasureType = catDistanceMeasureTypeMinimum
    MeasureDistance = MyDistance.Value
    MySelection.Clear
End Function
hi jagandeep sorry for the delay, i was out a while,
thank you so much for this code, it really help me a lot
i wonder if, this code just work for products? or it can be used also to mesure between partbodies within a part?
Unfortunately MeasureDistance and MeasureClash only works on Product Documents. And as per documentation we can't even use Measurable to measure minimum distance between two bodies in a single part.
V5 Automation Documentation said:
Measurable (Object)
System.IUnknown
System.IDispatch
System.CATBaseUnknown
System.CATBaseDispatch
System.AnyObject
Measurable
The interface to access a CATIAMeasurable Get measurements on the object.
Two types of measurement can be done:
itself : gives dimensions related to the object itself (ex the radius of a circle).
between : gives dimensions related to another object (ex the distance between two products). A restriction occurs for distance between: bodies (CATBody) cannot be measured.
This is a shame on Dessault's Part.
there is an option in the assembly workbench - distance and band analysis that you can use to measure the distance between two parts. i don't know if it's possible to access it through a macro though.
thank you so much for your answers
i will try different ways to find a solution for this.
thank you
