GetUserAttributeAsString("myTitle", NXObject.AttributeType.String, 0) what if obj hav'nt t
Ehaviv
Computer
IL
Hi
How I control this statement
if the object have not this title
I tryed try catch but that not elimunate the runtime error.
I want if the object hav'nt this title to skip and do nothig
how I acheve this.
Thanks in advanced
def_res_value = body1.GetUserAttributeAsString("myTitle", NXObject.AttributeType.String, 0)
You can use the .HasUserAttribute method to test whether an attribute with a particular title exists on the given object.
www.nxjournaling.com
Hi Cowski and thank you.
I want to ask your opinion about speed issue.
Actually I used sn arrayinfo of object
attributes with a for each that check
if a title exist ...
but now I want to try the above statement
and also I need to use hasattribute with it.
witch one you think is optimal for speed.
Thank you again.
Offhand, I don't know which would be faster. You'd need to write some code and do some testing to determine that.
Thank you.
Yes I think I'll do some testing.
