I have a bolt that is now damaged and needs replacement. The bolt has the normal 6 lines indicating it is a SAE Grade 8 bolt, but also has a small triangle between two of the lines. I don't recognize this marking and can't find any references stating its meaning. What does this triangle mean?
It's a 5/8-11 x 3" partially threaded, if that matters.
