OhioAviator
Hi All,
We are starting to design a system where the motor control center is feeding power to various motor and other loads at 480Vac. The difference is, we want to include an insulated non-current carrying conductor that will serve as a 'ground-check' conductor. The idea is to land one end of this 'ground-check' conductor on an unused terminal in the MCC bucket and connect the load end of this same conductor to a ground lug in the motor terminal box. The reason for this? Once per year we are required to measure the resistance of the grounding conductor of the motor circuit cable. This 'ground-check' conductor will serve as one-half of the ground/ground-check loop. Knowing the resistance of the ground-check conductor, we can subtract that ground-check conductor resistance from the total resistance to determine the resistance of the ground wire itself.
Since the usual colors for 480V circuit conductors are Brown, Orange, Yellow + Green (ground), what color should this ground-check conductor be?
Thanks!
J.R.
Galatians 2:20
Thanks!
J.R.
Galatians 2:20
