kimseunghee
- Jul 12, 2007
- 35
The lighting switchboard is derived via 480V/208V transformer from 480V main switchboard. The transformer is DYn and the secondary is solid grounded.
I'd like to use 208V line-line voltage to small motor and 120V phase-neutral to lighting fitting each.
Both feeder breakers on lighting switchboard(208V,3ph) will open against ground fault ?
