having trouble with trimming to a curve then aligning
connorsfc
Chemical
Mar 23, 2011
7
Hi
I'm still somewhat of a rookie with NX, so apologies if the question is really easy.
I have an offset hole that is coming into the outer body at 35 degrees, I'm trying to place a inlet tube into that hole (which I've had no problem doing). I can't seem to get the tube to be either trimmed in a way so I can face blend the inner side of the outer body with the inlet tube. I've tried just using a simple datum plane, but that doesn't seem to work. I can't seem to get a datum plane to follow the inside curve of the outer body, even if I do it completely separate from the assembly.
If I use an extrusion to subtract the portion, it won't let me use some of the assembly contraints.
Any advice?
Without the actual parts there is little that can be done in terms of suggestions. It would just be guessing and speculation as what you've actually got.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Could you provide the assembly as well as a better description of exactly what it is that you're attempting to model. The original image is very ambiguous.
John R. Baker, P.E.
Industry Sector
Cypress, CA
