Hello, could you someone explain to me the effect of increasing the process fluid flow rate, in the tube, in regards to the heat transfer to the cooling water in the shell?
What happens if I increase or decrease the flow rate in the tube by keeping the cooling water flow rate constant?
What happens if the cooling water flow rate in increased or decreased with the process fluid flow rate constant?
I was reading a heat exchanger chart which shows the outlet temperature with respect to the process fluid flow rate..it showed the inlet temp as 500F and with a flow rate of 2GPM, the fluid cooled down to 300F..and with 1GPM it went from 500F to 200F..by increasing the process fluid flow rate, is the heat transfer rate reduced?
