Does anybody know of a facility that can performance test a heat exchanger? The heat exchanger type is basically a tube bundle between two heads that is submerged in water for cooling hydraulic fluid. It is not a shell and tube heat exchanger. I would like to have the heat exchanger tested at different flows, inlet temperatures, and ambient temperatures.
