JenB8
Materials
- Jan 18, 2022
- 1
I work at a naval manufacturing company, and we are investigating the option of bringing heat-treating in-house for one specific part we produce... The part is made from 8620 material and welded into its configuration before heat treating... Below are some of the specs set by our customer and heat treating notes:
- minimum tempering temperature is 975F
- hardness must be 30-33 HRC
- no more than 0.010" total decarburization and approximately 0.03" partial decarburization
- enhanced carbon (carburization) is not permitted
Here's my questions:
1. Does the hardening and tempering processes need to be conducted in an inert atmosphere?
2. How would you determine a cooling rate that is necessary to achieve the above specs?
3. Is there a way to integrate a quenching system into the hardening furnace or would it be better separate?
4. At what temperature does the material need to reach before quenching?
I am just a little clueless when it comes to heat-treating, so any and all suggestions would be appreciated. Thanks!
