Heat treatment requirement of F468 grade 625 after manufacturing by rolling
Ratheesh_n
60
AE
Dear Team,
F468 grade 625 manufactured by rolling operation and heat treatment (annealing) done on the bar prior to manufacture of studs. No annealing done after the rolling operation is completed. Is it acceptable
Ratheesh
What does F468 say about that? In fact, F468 has the last say, else it is not F468.
DHURJATI SEN
F468 doesnt state the stage of heat treatment .. Concern is the impact of metallurgy and mechanical properties after rolling operation .So did the re-heat treatment is required ...
You have already answered your question, if F468 is silent then it is acceptable as per F468.
DHURJATI SEN
But make sure that F468 does not ref another material spec that does require anneal. Many 625 specs have two or three acceptable HT conditions (none, full solution, SR anneal).
