Heavy Metal removal from run-off water from Ash pond
kaushalnsuthar21
3
Hello all,
I am requested by Owner to provide scheme for Heavy metal removal of Run-off water from Ash Pond.
It is Coal fired thermal power plant. Owner is not having the details of heavy metal content in the run-off water.
Can anybody help me and suggest the way to decide a scheme. Anyone having experience in providing such Heavy metal removal treatment scheme in thermal power plant Ash/
Kaushal
Alkaline or sulfide precipitation processes are typically used.
books
Thanks a lot Bimr,
can you please share if you ever had experienced such system in Thermal power plant.
Can you suggest on how to estimate the heavy metals contained in Ash pond run-off water?
We dont have any details as such regarding heavy metal in the ash.
There is no generic analysis because the contaminants are in the coal that the plant is burning. Each coal is slightly difference as is the metallurgy of the power plant.
The attached document has ranges for the contaminants. Use the median value as an estimate.
 http://files.engineering.com/getfile.aspx?folder=fd51615d-a935-4e68-909c-c628bc802965&file=EPRI.pdf
Dear BIMR,
Thanks a lot. That means, in absense of heavy metal data, I can use this data as a assumption for the sizing of treatment plant.
Kaushal
Yes you can. But it is advisable to check the carbon analysis for heavy metal content and accordingly adjust the pH of water.
Here I considered heavy metal removal by pH correction method.
Krunal Bhosale
All about Water and Wastewater Treatment
