Hello I am using macro from this th
Raul Berame
Automotive
Jan 12, 2023
11
Hello I am using macro from this thread for exporting PDF files from CATIA Drawing. Is it possible to modify code to automatically convert multiple sheets into 1 file?
Here's the code I used from this Fourum:
Sub CATMain()
'Retrive the active document
Dim Doc As Document
Set Doc = CATIA.ActiveDocument
'Test the document's type, if it is not a drawing document the macro stops
If TypeName(Doc) = "DrawingDocument" Then
Dim DocDocument As DrawingDocument
Set DocDocument = Doc
Else
MsgBox "This macro can be run with a drawing document only."
Exit Sub
End If
Const WINDOW_HANDLE = 0
Const NO_OPTIONS = 0
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder _
(WINDOW_HANDLE, "Select a folder:", NO_OPTIONS, "C:\Scripts")
Set objFolderItem = objFolder.Self
objPath = objFolderItem.Path
MsgBox objPath
Set objFolderItem = CreateObject("Scripting.FileSystemObject")
Dim ShortPartNo, strFolderPath
ShortPartNo = Left(Doc.Name, 8)
MsgBox ShortPartNo
strFolderPath = objPath &"\"& ShortPartNo & "\"
MsgBox strFolderPath
If Not objFolderItem.FolderExists(strFolderPath) Then
objFolderItem.CreateFolder(strFolderPath)
End If
Doc.ExportData strFolderPath & ShortPartNo& ".pdf", "pdf"
CATIA.DisplayFileAlerts = False
End Sub
Printing all the sheets as one single PDF file should be straightforward to do just by checking the Export settings in Tools / Options.
Thanks MarkAF! But may I know when exactly the OPTIONS found? Please advise. Thanks
Should be this (now that I'm back in front of my screen):
Tools > Options > General > Compatibility > Graphics Formats
Under the heading 'Export (Save As)' check the box "Save multisheet documents in a single vectorial file"
Then test and verify the result.
Cheers
Mark
Hello Raul Berame,
Does this macro save all the drawings opened in CATIA window into pdf or only active sheet it will save?
Thanks in advance
Yeah if I use PDF Batch utility, after Exporting to PDF line weights appear thicker. Is there any settings do I need to change in CATIA.
