I am a mechanical engineer and want to design an automated Bartender. This is just for fun. I need to know how I can control fluid in a pipe. The pipe will be set up verically and be blocked off by a valve or something. Then I need to do a control of somesort to tell the valve to move at a rate to allow a certain amount of fluid to pass and then close again. I checked on Mcmaster Carr and other and found information on solenoid valve etc. My problem is I dont even know where to start. Is this difficult? I need to keep this off the shelf and as cheap as possible
