I am putting together a proposal for the existing pedestrian platform shown in the google image attached. The structure and Levy are both open to the public 24/7. I assume as part of the lease agreement the Hotel (Client) is responsible for servicing this structure. I would appreciate feedback on setting up my design criteria (assuming my proposal is executed). The PDF is annotated with existing conditions and end-use environment. Let me know if you need more information before responding. The structure consists of a series of concrete frames (width of the walkway) with glulam beams framing into seated steel plate buckets, which are in turn bolted into the sides of the existing concrete beams. A group of these steel buckets appear to be suffering from substantial rust, although I did not observe delamination. The concrete columns are founded in the bay (into what type of foundation I do not know) and the glulam beams bear on concrete pads at the street level. The scope of work includes designing/specifying replacement glulam beams for existing that are rot (one of the interior glulam beams has completely sheared off it's concrete beam-supported bucket (yikes!! Sorry I don't have photos--it's a terrible sight to see)). I read the 11 page Technical Note, Preservative Treatment of Glued Laminated Timber, Number S580D, July 2013 and understand the basic pressure-treated options available based on the end-use service condition of the glulam beam. I assume this is a marine application and all the glulam supplier websites I visited say no to the use of naturally durable species (Cedar, etc) for use in Marine applications so I'm thinking I need to specify an approved artificial treatment. Also, are there any AASHTO requirements and what is an appropriate engineering term (name) for this structure?
Thanks,
Mike (PE in California)
Thanks,
