Hi all, I just recently built my SE Tube amp with parafeed output transformer. Everything looked fine and as expected when I tested it with a 8 ohm resistor dummy load. However, as soon as I hook up to a speaker and crank up my signal generator, I heard a loud high pitch noise and the noise vary in pitch as I vary the input frequency. The outputs apprear normal on scope. I did not see any oscillation. I tested it on a different speaker and I have the same result.
I ran out of thought what would be wrong. Do you have any suggestion?
