I'm looking for an explanation of the feature control frame outlined in red within the attached.
I'll take a stab at the meaning: The position of the axis of the shaft (along the entire length of the shaft) must be within a 1.1 diameter circle after the part is first fixtured relative to datum A and then to datum B.
Is this accurate?
Also, what does the "L" (least material condition) mean as applied to datum B? Does that mean when the inspection fixture is produced, the fixture should be at max material condition (4.52 as drawn)?
Thanks for taking the time!
Is this accurate?
