JoeChem
Chemical
- Dec 9, 2002
- 50
Greetings
I have been given the responsibility to begin conceptual design work on a batch chemical synthesis process that employs anhydrous HF as a solvent. Essentially, the process involves feeding solid staring materials to a batch reactor system followed by a crystallization and isolation of a solid final product by filtration. In addition, the starting materials and final products are very air and moisture sensitive.
I have no experience at all working with HF solvent or with air/moisture sensitive solids at a large scale. I was hoping to talk with someone that has had experience with this kind of system.
Some immediate questions come to mind:
Are there any published guidelines out there on how to handle anhydrous HF safely?
It is my understanding that anhydrous HF is not corrosive to stainless steel. Will nitrogen purging procedures be adequate to lower the moisture level within a batch tank system to acceptable levels to maintain an "anhydrous" environment?
I am unsure how to handle large amounts of air/moisture sensitive solids. The problem is how to open a bulk container (drum?) and feed the material to a batch tank without damaging due to exposure to the environment? Does anyone have experience dealing with this kind of problem?
Any help/tips/guidance will be greatly appreciated.
JoeChem
JoeChem
