I have to detail a gear transmission in which positions and orientation of both gears were already chosen. I can't change axes angles beacuse some parts to which these gears are mounted were already made. Outer dimensions of gears are also fixed because of gear ratio.
I need help with choosing a right type of gears. I've attached a STEP file of gear pair. Maybe someone with more knowledge and experience with gear desigh will quickly see which type of gear should I use. I was thinking that I should use straight or spiral bevel gears. Crossed helical also came to mind but after closer look it looks like it has to be beveled.
Thanks for help in advance.
