E M
- Mar 15, 2018
- 41
A "modern" house I'm currently designing has 2 stacked front porches 10' deep by 35'-0" long (which is the total width of the house.... narrow lot). They are covered with a simple rectangle 3.5 in 12 hip roof (trusses) that is the same roof that covers the main body of the house. Because of the style of the house, I'm keeping my front columns at the porches supporting the roof to 3. So, I have one span 23'-0" +/- and another span 10 or so feet (yeah I know it doesn't add up). What I would like to do is take posts (for all practical purposes) all the way down from the roof and through the 2 porches and have the posts bear on top of a 10" thick cast in place basement foundation wall. Assuming that my footings at these point loads (under the basement wall) are sized properly to support the posts, am I right in my thinking that so long as the posts are fully on top of the basement wall (not necessarily centered but fully on top) that the the basement wall will be able to handle this transfer to the footing without needing to thicken up the basement wall at the areas of the posts? If so, would I need additional reinforcing at these areas? Right now have drawn in 5.5 x 16" glulams as a starting point for both spans and 5-1/2" Posts. Basement walls are 10" thick..... possibly dropping to 8" if that wouldn't affect this "detail".
Just trying to understand this conceptually right now. Will be designed by an engineer.
