Help with MOSFETs
swb1
40
Using power Mosfet MGSF1N03LT1 (On Semiconductor), the FET takes a long time to turn off (1.2 microsecs.). Why is this?? I need for it to turn off quicker. Any suggestions on different Mosfets that will turn off quicker with the same characteristics as the On Semiconductor part??
Thanks,
swb1
Sorry :-) the data sheet says that the turn off time Td(off) is typically 16 ns with Vdd = 15Vdc, Id = 1.0 Adc, and RL = 50 Ohms. In my circuit, Vdd = 6Vdc, Id = 30mA, and RL = 100 Ohms and it takes 1.2 microsecs to turn off. Why is this??
swb1
Excess capacitance on the gate?
"It's the questions that drive us"
Any mosfet has large gate C -- sometimes many nF-s.
You need hi-current driver to drive the gate fast
enough. If the Rout is high, the R*C time constant
will slow it down.
Plesae read FAQ240-1032
WEB: <
MOSFET gate drivers typically source & sink half an amp or more to turn on & turn off fast.
Repeating the above question... what's your drive circuit like?
Ditto with the above comments on drive circuitry.
FETs need to establish an electric field to control current flow.
As you may remember from physics, the voltage on a capacitor doesn't change instantly, you have to transfer charge for the voltage to change. The more current your driver can source or sink into/out of the gate, the faster the voltage will change on the gate and the faster the FET will turn on/off. There are other parasitic capacitances in the FET as well, but the gate-to-source capacitance is usually the one that lengthens switching time considerably.
