hexagon symbol on a drawing
idanbrk
20
hi all,
i recently received a drawing of a part that had a hexagon shape , the guy who made this drawing used a symbol to indicate that this is a hexagon, you can see an example of the symbol he used in the attached file, it looks like the diameter symbol but with a hexagon instead of a circle, my question is if this is a valid symbol to use in a drawing? (according to iso or asme )
thanks.
 http://files.engineering.com/getfile.aspx?folder=0a7b01ab-e76b-4f99-9a0c-43b9bafbe4d4&file=hex.jpg
No
If you are going to make up your own symbols, you need to include some form of legend. That said, I would not create such a symbol unless you were making a whole library of hexagonal parts and the redundancy has merit, but even then I'd be hesitant.
As for your bolt dimension template, you should not base a manufacturing drawing off of that precedent. It is a general reference-only diagram. The actual tolerances and dimensions are controlled by the various ANSI/ISO/Whatever standards the bolt claims to be made in compliance with. The diagram is providing a reference for people to know about very general sizes.
To dimension the hexagon, you'd probably need to specify either the inscribed or circumscribed diameter, and dimension a face and angle to establish a tolerance (with the number of places (6) called out). There may be a more elegant way, but that's my off-the-cuff Monday-morning suggestion.
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
For drawing requirements, here is an example from ASME B18.2.6:
Which will immediately rise the question "What is legend?": thread1103-391205
