hi guys. My question is " how to d
Jahangirktk
1
hi guys.
My question is " how to design header size for water pipes lines"
My response is that you need to expand your post to a lot more than one line.
My answer is “with pencil, paper, a few good references, and a calculator/slide rule”.
Have you no shame?
Good luck,
Latexman
Engineers helping Engineers
Latexman: seems he doesn't have pencil / paper / references / or sufficient fingers for calculating.
IT thought I'd leave this one to you guys..
We get easy ones in sparky land. Check this one:
thread238-457335
[edited][!]
Shucks!! the absurd thread (linked above) was removed. It was a picture of some wires entering a broken generator casing and the guy's entire question was, "Help me fix this generator". No other text.
[/!][/edited]
Keith Cress
kcress -
Considering you were able to only elaborate a question up to " how to design header size for water pipes lines", my answer will be "With difficulty."
Maybe logging back in to look at the response would also help!
