rossob
- Jul 22, 2007
- 70
I'm just wondering if there is a way you can hide certain bodies of a component in a drawing? We have an item which is essentially a piece of angle with a 5mm end cap (see attached image). This item is purchased as a single item, with only one part number. The current drawing (done in Mechanical Desktop quite some time ago) has localised parts and the drawing shows the fabrication details of the complete item, but also a detail view of ONLY the end cap.
I have modelled this in NX using two extrudes, and thought that if I created a drawing I could just show a detail of the end cap, somehow, by just hiding the piece of angle. I can't seem to be able to make this work. Is there a way i can do this, without making this item an assembly of two parts?
Ross
NX5.0.2.2 WinXP SP2
SolidWorks 2007
Ross
NX5.0.2.2 WinXP SP2
SolidWorks 2007
