This is what I got...
" Thanks for your phone call regarding the Pureflow Filtration system located at the ....... well water treatment facility. In reference to the pH increasing from 7.0 (raw water) to 10.0 (filtered water), I offer the following information:
a. The pH increase is caused by the Pureflow Pm-100 catalytic adsorptive media. The increase in pH is common and is dependent on the raw water of each well.
b) This pH increase is temporary and will be reduced when the PM-100 media becomes conditioned by the Iron / Manganese in the raw water which causes a "patina" to develop on the surface of the media. When the PM-100 media develops the coating the pH will be reduced to just above the raw water pH.
c) PM-100 adsorptive / catalytic filter media operates as follows:
Iron and Manganese, along with other dissolved contaminants such as Arsenic, Hydrogen Sulfide, organic carbons, etc., are oxidized by chemical pretreatment, followed by an inline static mixer. The Iron and Manganese are precipitated as metal hydroxides. The Arsenic is removed by co-precipitation with the Iron and / or an adsorptive reaction. The Iron and Manganese are filtered on the PM-100 media where an adsorptive reaction occurs on the water / media interface. There, localized zones of an increased pH assure the formation, and the maintenance, of an active, adsorbent, hydroxide floc. The PM-100 media does not require regeneration and is backwashed at a rate of 20 gpm / ft2 of media, with filtered water.
d) If the temporary increase in filter effluent pH is unacceptable we offer the following remedies:
· Install a temporary acid feed pump / tank to lower the pH (Citric or Muriatic Acid can be used).
NOTE: Pureflow will provide the chemical feed pump and tank at no charge.
· Feed Ferric Chloride ahead of the filter (if there is little or no Iron in the raw water). This will cause the media to become conditioned faster and may lower the pH of the filtered water.
· Blend the filtered water with another water that has a lower pH until the media becomes conditioned.
e) As the PM-100 media becomes conditioned with the Iron / Manganese the pH will gradually come down to a level similar to the raw water.
f) PM-100 media will remove the Iron / Manganese in the raw water to levels well below the EPA / DHS MCL for each contaminant and most often reduces the Iron / Manganese to (or near) non-detectable levels, typically at filter loading rates of up to 10 – 15 gpm / ft2 of media. PM-100 is a permanent media, is not coated (and, therefore, there is no coating to wear off) and does not require Potassium Permanganate feed as a regenerant.
We appreciate your concerns and will offer any assistance you need to resolve the above referenced subject. Please call if you have any questions regarding this report.
