High Powered Demagnetizer
RICH535
18
I need to design a high-powered demgnetizer that will be line-powered (120-240VAC, 50-60 Hz). Is there any good reference material on the subject?
Define "high-powered"...
Dan - Owner
Most of these devices are just a coil and in some cases include an iron core. I cannot picture any that would allow 'both' voltage operation. You may be able to use a 240V unit at 120V. It may be far less effective in that case.
Keith Cress
Flamin Systems, Inc.-
If there's just a coil, it would probably work better at 240V. At least it might work better until it got so hot that it melted itself down. :)
Many of them have a PTC in series to limit the current.
Rich, you might have more success if you Google "degaussing" rather than "demagnetizing".
Two coils, each 120V, connected in parallel for 120V and in series for 240V would work.
Degaussing: For removal of unintentional residual magnetism. Like a TV screen.
Demagnetizing: For removing the field of a magnet. Or erasure of magnetic storage media. See also "Bulk Eraser".
Keith Cress
You might want to move this to a group on ships or military topics. Submarines are degaused requrlarly.
It's not done with 120/240 volts I am pretty sure. You can get a 240 volt welder that will put out 200 amps DC but that would not be considered "high powered" if your demagnatizing a submarine.
