ampersand
- Sep 2, 2005
- 30
I'm in California, and we just switched over to the IBC. One new requirement is that shearwall sill plate anchor bolts now have to have 3"x3"x0.229" plate washers. Now, suppose you have a shearwall built on a framed floor, and the floor framing bears on a mudsill, which sits on the foundation. Because the mudsill will have a 2x rim joist at the outer edger, which robs me of some room, it seems that I will always have to use a 2x6 mudsill in this situation. Or 3x6, depending on shear loads.
This is not a big deal for new construction, but now, every time I build a new shearwall over an existing foundation, I'll likely be working with a 2x4 mudsill, which is not big enough, so they will have to remove the floor framing, replace the mudsill, replace the floor framing, etc. A lot of extra work for a small project.
Does anyone have any thoughts on this?
