Hey all,
I'm having some trouble with a PMOSFET which I use to supply power to a thermal printhead. The problem is, after several days, or several power cycles, the PMOSFET seems to become a short circuit, and can't be turned off.
In the schematic provided, Q1 controls the turn-on and turn-off of the PMOSFET T1. There is a power sequencer that enables T1 after the system is ready. This seems to work fine for a while, but then the PMOSFET won't turn off, even when its gate voltage is 24V (Q1 off, R84 pulls gate voltage up to +24V).
The specs for the transistor T1: Alpha and Omega Semiconductor AOD4189: 40V, 40A, Vgs(th) ~ 3V @250uA.
I know there is a lot of capacitance here, and I added D7 to help conduct when the power +24V is turned off, with those big capacitors fully charged. I thought maybe the body diode was failing, but adding D7 has not helped. What I have noticed, is that the resistance measured between the source and drain is very low after the "failure". I measured some new pmosfets and they seemed more normal (high resistance). Also, did a diode check on the PMOSFET body diode, and also on D7. D7 is still functional, but the Q1 body diode seems like a short.
Any thoughts on what might be happening here?
B
B
