Hi, would appreciate any thoughts for a pump to handle the following duty - initial thoughts are a VS6 can pump due to the low NPSHA however the very high suction pressure is a concern from some pump suppliers that I have discussed application:-
Duty:-
Liquid: NGL (1 duty 1 on standby)
Design code: API 610 10th Edition
Flow rate: 40m3/hr
Suction pressure: 56.87 barg
Discharge pressure: 60.17 barg
Differential head: 65.2m
SG: 0.513
Vapour pressure: 57.87 bara
Pumping temp: 27 Deg C
316L SS construction (A-8)
Dual pressurised seals C2A3A0253B
Power supply 415/3/50
Thanks,
Duty:-
Flow rate: 40m3/hr
SG: 0.513
Thanks,
