I am trying to seal two long plates from industrial oil. This green plastic body is at the bottom of hot oil tank. plates expose to oil. It is difficult to overmold so I am thinking of push in these plates in to plastic. but I will have leakage problem. Do you think epoxy seal around plates will survive in oil? Oil temperature can go from minus degrees to 160C.
