downranger
- May 20, 2015
- 5
Hi guys,
I am busy diagnosing the cause of high temperature within a hydraulic circuit which has not been problematic in the past. The circuit runs a low-displacement, high force application. The fluid heats up well past 220F after a couple hours. We suspect that the problem may be the amount of fluid travelling from the dump valves to the reservoir, since lots of fluid is being dumped (can feel and hear) and the piping becomes very hot to the touch.
There is a flow control valve which is between the dump-valves in the manifold and the reservoir. This valve is 7/8 of a turn open (full range is 8 turns). I suspect that the pressure drop over this partially open valve is the source of the heat. What is the appropriate setting for this valve? The circuit path goes pump -> filter -> directional cartridge valve -> Port in parallel with dump valve.
Is there any reason for this flow control valve to be partially open/closed? If I open it more, there will be less sudden pressure drop, and thus less heat generation. If I close it, all fluid should travel through the relief valve to the reservoir causing the pump to heat up more. Any thoughts?
