hgjor
Materials
- May 9, 2008
- 6
I need a metal (alloy) with the highest possible thermal conductivity to use as heat exchanger. I have tried pure copper, but I noticed severe temperature corrosion at 450°C. I have also tried nickel plated copper, but the nickel comes loose at sharp edges.
Does anyone have a recommendation for a metal alloy with excellent thermal conductivity (preferably the same as copper) and high temperature corrosion resistance ? The metal (alloy) will be used as heat exchanger and should not be excessively expensive.
Many thanks for your help.
Herman
Herman
