Hi all,
we are realizing a project on helicopter that needs high Dc voltage for operation. The trick is that the generation must be compromised with low weight and volume.
One solution could be to install a 270V generator and a converter to achieve the desired -60/+600 Volts DC.
Do you know manufacturers that could be contacted to get practicable/alternative solutions?
