Hole Notes (ASME Y14.5M-1994) 4
ModulusCT
212
So we've had a question about our notes for some time where I work... Simply put, we're not sure how to do it. I have an idea of how it should be, but I'm unsure... Maybe someone here can help me out.
A few examples:
If I've got a tapped hole (#2-56 UNC 2B) with a depth of .18, I would think that the hole note should look like the following:
2X #2-56 UNC 2B <depth symbol>.180
... but what does that mean in regards to the drilling operation done before tapping? Is the drill tip going to be held to the same .18 depth dimension the tap is? If not, what is the proper way to control the depth of the drill? I would assume the following:
2X DRILL <depth symbol>.200
,.. and if I want the hole fully threaded? Is that even possible? What about the drill tip? Is that part of the depth stated on the drawing? Or does it always go beyond the stated depth value by some amount?
Lastly, we use a lot of helicoils on our parts. How would one go about making a hole note for a helicoil insert while simultaneously communicating the parameters below:
10X DRILL <depth>.22
#2-56 UNC 2B
1.5X DIA. HELICOIL (TANGLESS)
Is that correct? Will the drill used for the .22 depth hole be the proper diameter to allow the end of a threaded fastener to pass through? Or will it be a pilot hole drilled for a #2-56 thread? I would obviously want to communicate that the drill diameter is whatever is appropriate for the helicoil insert.
Thanks for the help!
I'm not a vegetarian because I dislike meat... I'm a vegetarian because I HATE plants!!
I'd forget putting it in the call out as it may be confusing.
I'd just go with directly dimensioning the max tap hole depth in the section view and hence not need to specify its diameter. I'd make the call out my min full thread dimension - or maybe even put that in the section.
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
