TrailMaker004
- Apr 5, 2010
- 20
The (2) .119 diameters on the attached dwg are raised bosses. The .226 diameter is a hole. Datum A is the common planar surface these features are normal to. What we are trying to accomplish with the GD&T is first hold the 2 bosses center to center dim to .000 TP if at MMC with bonus tolerance as the boss sizes both on the datum D feature and the opposite reduces (this is for a mating part fit). We then want to establish the location of this 2 boss pattern relative to the .226 hole with a TP tolerance of .004 (i.e. the 2 boss pattern should be centered to datum B within a .004 tol zone). Rotation angle of the three feature pattern is not important at this point.
This should be elementary considering all the GD&T we assign here but we are scratching our heads. Need some feedback on this.
