johnwm
Computer
- Sep 26, 2002
- 806
Having retired recently, and looking to take up a 'hands-on' sort of pastime, I have recently got involved with throwing pots and other types of clay building. These potters seem to use several machines which seem to be awfully poorly designed and I have been tempted to have a look at some alternatives.
I have been looking at an extruder. The clay to be extruded is very plastic and malleable. In the current design a wooden piston is used in a piece of 4" NB PVC soil pipe. Even with the wooden piston boiled in lube oil to reduce water absorption I am still seeing 10 to 20 thou variation in diameter with changes in ambient conditions. Wood is also anisotropic so the piston will not stay round. If the piston is tight enough to not leak past in it's small condition it becomes too tight to remove/replace for a fresh clay charge when expanded. If it is made slightly small then it lets past too much to be of use.
I immediately thought to use a pneumatic cylinder lip seal, but I can't find one that is a decent fit in the tube without having a special manufactured. Potters are a tight lot, so these devices really need to work, but at a very low cost, so specials from a manufacturer seem to be out of reach.
Qusetion: Does anyone have experience of home made lip seals - or any alternative ideas? I have been thinking along the lines of machining a lip-seal shaped groove on the face of an aluminium plate and then moulding my own. ?Meltable moulding rubber compound? ?Polyurethane casting compound (as used to take intermediate female moulds off male masters)?
This will never be a "commercial app" - just something to amuse me and our local potters group, but it may pose some engineering questions.
Ideas please?
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts
Ideas please?
Good Luck
johnwm
