Calculor1 obviously mis-spoke when he said the structural face was cast first. The outer, architectural wythe is always cast first, normally reinforced with WWF. The insulation is applied over the fresh concrete while still plastic, and connectors are inserted in pre-drilled holes in the insulation. The connectors are, I believe, normally installed at 8" on center in each direction. They are stronger than heck, and support the full weight of the architectual wythe when the panel is lifted. The two wythes are not connected together in any way, under normal circumstances (there are axceptions), because it is important that the wythes move independently for thermal reasons, and so as to not create any thermal breaks in the wall.
The reinforcement, lift & brace hardware, embeds, etc. for the inner structural wythe can be placed, and concrete poured, immediately... supposedly. That is generally not the case. Normally the outer wythe is given at least 2 or 3 days to cure before proceeding with the Structural wythe.
If anybody would like more info, see thermomass.com.
It is my opinion that the cracks were caused by restraint between the architectural wythe and the casting bed, normally the slab-on-grade. Depending on when the slab was poured... differential shrinkage between the two... inadequately applied bondbreaker, etc. It gets worse the bigger the panel is. Also, tilt-up cast on a slab-on-grade may cross a control joint in the slab. The joints are normally taped so they don't "read" into the face of the panel, but the movement at the joint can literally pull the yet-to-harden concrete apart. I've seen it, on more than a few occasions.
