foundrydude
I am having a problem with 17-4 PH investment castings that are distorting during machining. My customer wants to machine in the fully HTR condition, Homo + Solution + H925.
They are 6 inch diameter, thin-wall collars that are used to strap an A to A missile to a fighter wing.
We hot size at 1900 F, soak time 30 minutes, after annealing, but prior to age harden. The castings are perfectly to dimension when delivered, however when un-clamped after machining the inside diameter, they spring closed some. Improper heat treat? Cold work stress imparted during hot sizing? Does not happen all the time. Any suggestions are welcomed.
Thanks,
Foundrydude
Thanks,
Foundrydude
